Acer Chromebook CB0311-1H-C1MX Heatsink Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
61
All Time:
293
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The purpose of this guide is to demonstrate how to properly replace a faulty heatsink (also known as a “bus bar”) of the Acer Chromebook CB0311-1H-C1MX. The heatsink distributes high electrical currents across the motherboard and dissipates the heat across its surface in order to cool the device. If the device is experiencing overheating, the heatsink may need to be replaced.
Tools
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Back Cover: step 1, image 1 of 1
      • Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 2, image 1 of 1
      • Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
      • Continue using the iFixit Opening Tool around the entire edge of the case.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Battery: step 3, image 1 of 1
      • Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 4, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 4, image 2 of 2
      • Gently push on either side of the silver connector so that it no longer covers the battery cable.
      • Disconnect the battery cable by pulling it straight out.
      • This component is called the Flat Topped Connector.
      Ask FixBot
    3. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 5, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: step 6, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: step 6, image 2 of 2
      • Remove all four 4.7 mm screws from the heat sink with the JIS #1 screwdriver.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 7, image 1 of 1
      • Remove the heatsink from the laptop.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 61
All Time: 293
