Nintendo Switch 2 Battery Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Nintendo Switch 2 Battery Removal, Weaken the adhesive: step 1, image 1 of 1
      Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • Tilt the bottom edge of the console upward.
      • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol inside the battery well from its bottom cutout to weaken the adhesive.
      • Make sure not to puncture or scrape the bottom of the battery.
      • If you're using adhesive remover, follow these preparation steps first.
      • Hold the console upright for 1–2 minutes for the solvent to flow under the battery and weaken the adhesive.
      Ask FixBot
    2. Nintendo Switch 2 Battery Removal, Lift the battery: step 2, image 1 of 3 Nintendo Switch 2 Battery Removal, Lift the battery: step 2, image 2 of 3 Nintendo Switch 2 Battery Removal, Lift the battery: step 2, image 3 of 3
      • Don't bend the battery. If you see the battery bending, or if you're having difficulty prying, apply more solvent.
      • Insert the flat end of a spudger underneath the battery from the battery well cutout.
      • Slowly pry the battery up until its adhesive is fully separated from the frame. You can pry against the metal grille along the bottom edge of the console.
      Ask FixBot
    3. Nintendo Switch 2 Battery Removal, Remove the battery: step 3, image 1 of 1
      • Remove the battery.
      Ask FixBot
Nick Schultz
65,446 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 297
