Shop the Holiday Gift Guide
Nintendo Switch 2 Back Cover Installation
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
28
All Time:
248
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Nintendo Switch 2 Back Cover Installation, Prepare the back cover: step 1, image 1 of 3 Nintendo Switch 2 Back Cover Installation, Prepare the back cover: step 1, image 2 of 3 Nintendo Switch 2 Back Cover Installation, Prepare the back cover: step 1, image 3 of 3
      • Fully pull out the game card tray.
      • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
      • Check the microphone to ensure it's fully seated in its slot in the frame.
      Ask FixBot
    2. Nintendo Switch 2 Back Cover Installation, Install the back cover: step 2, image 1 of 3 Nintendo Switch 2 Back Cover Installation, Install the back cover: step 2, image 2 of 3 Nintendo Switch 2 Back Cover Installation, Install the back cover: step 2, image 3 of 3
      • Align the top of the back cover with the top of the console.
      • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
      • Press along the top edge to fasten the clips securing the back cover to the console.
      Ask FixBot
    3. Nintendo Switch 2 Back Cover Installation: step 3, image 1 of 2 Nintendo Switch 2 Back Cover Installation: step 3, image 2 of 2
      • Squeeze the rest of the back cover and console together to fasten the clips.
      Ask FixBot
    4. Nintendo Switch 2 Back Cover Installation, Install the back-side screws: step 4, image 1 of 3 Nintendo Switch 2 Back Cover Installation, Install the back-side screws: step 4, image 2 of 3 Nintendo Switch 2 Back Cover Installation, Install the back-side screws: step 4, image 3 of 3
      • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
      • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    5. Nintendo Switch 2 Back Cover Installation, Install the side screws: step 5, image 1 of 2 Nintendo Switch 2 Back Cover Installation, Install the side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to install the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    6. Nintendo Switch 2 Back Cover Installation, Test the console: step 6, image 1 of 2 Nintendo Switch 2 Back Cover Installation, Test the console: step 6, image 2 of 2
      • Power on the console and test functionality to ensure it's working as expected.
      Ask FixBot
    7. Nintendo Switch 2 Back Cover Installation, Install the stickers: step 7, image 1 of 3 Nintendo Switch 2 Back Cover Installation, Install the stickers: step 7, image 2 of 3 Nintendo Switch 2 Back Cover Installation, Install the stickers: step 7, image 3 of 3
      • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
      • Set the sticker into its recess, first on one side, then the other.
      • Use your finger or the flat end of a spudger to press the sticker into place.
      • If the sticker isn't sticking well, apply heat after you press it into place.
      Ask FixBot
    8. Nintendo Switch 2 Back Cover Installation: step 8, image 1 of 3 Nintendo Switch 2 Back Cover Installation: step 8, image 2 of 3 Nintendo Switch 2 Back Cover Installation: step 8, image 3 of 3
      • Repeat this procedure to install the left side sticker.
      Ask FixBot
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 28
All Time: 248
