Nintendo GameCube Controller Z Button Replacement
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: step 1, image 1 of 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Ask FixBot
  2. Nintendo GameCube Controller Z Button Replacement: step 2, image 1 of 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Ask FixBot
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: step 3, image 1 of 2 Nintendo GameCube Controller Z Button Replacement, Z Button: step 3, image 2 of 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Ask FixBot
9 other people completed this guide.
Sean Michel
2,750 Reputation
8 Guides authored
Cal Poly, Team 19-44, Regan Winter 2013 Member of Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Members
34 Guides authored
6 Guide Comments
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Reply Share
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
Justin Sebastian - Reply Share
My bad no pic it's a pelican wireless controller
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - Reply Share
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 160
All Time: 22,382
