Nintendo GameCube Controller Buttons Replacement
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: step 1, image 1 of 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Buttons Replacement: step 2, image 1 of 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: step 3, image 1 of 2 Nintendo GameCube Controller Buttons Replacement, Z Button: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: step 4, image 1 of 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Buttons Replacement: step 5, image 1 of 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: step 6, image 1 of 2 Nintendo GameCube Controller Buttons Replacement, Buttons: step 6, image 2 of 2
    • Remove the rubber backing that covers the buttons.
  7. Nintendo GameCube Controller Buttons Replacement: step 7, image 1 of 3 Nintendo GameCube Controller Buttons Replacement: step 7, image 2 of 3 Nintendo GameCube Controller Buttons Replacement: step 7, image 3 of 3
    • Use tweezers to lift buttons out of thier sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
Sean Michel
2,496 Reputation
8 Guides authored
Cal Poly, Team 19-44, Regan Winter 2013 Member of Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Members
26 Guides authored
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 99
All Time: 29,255
