Nintendo GameCube Controller Buttons Replacement
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: step 1, image 1 of 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Ask FixBot
  2. Nintendo GameCube Controller Buttons Replacement: step 2, image 1 of 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Ask FixBot
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: step 3, image 1 of 2 Nintendo GameCube Controller Buttons Replacement, Z Button: step 3, image 2 of 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Ask FixBot
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: step 4, image 1 of 1
    • Carefully unhook the cable that is looped around the peg.
    Ask FixBot
  5. Nintendo GameCube Controller Buttons Replacement: step 5, image 1 of 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Ask FixBot
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: step 6, image 1 of 2 Nintendo GameCube Controller Buttons Replacement, Buttons: step 6, image 2 of 2
    • Remove the rubber backing that covers the buttons.
    Ask FixBot
  7. Nintendo GameCube Controller Buttons Replacement: step 7, image 1 of 3 Nintendo GameCube Controller Buttons Replacement: step 7, image 2 of 3 Nintendo GameCube Controller Buttons Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
    Ask FixBot
20 other people completed this guide.
Sean Michel
2,750 Reputation
8 Guides authored
Cal Poly, Team 19-44, Regan Winter 2013 Member of Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Members
34 Guides authored
3 Guide Comments
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Reply Share
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Reply Share
How do you put the back back on?
Steven Enns - Reply Share
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 206
All Time: 32,925
