Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓If your GameBoy Advance SP AGS-001 or AGS-101 has a deteriorating shell, or if you’re looking to customize it, use this guide to replace the shell.
Before using this guide, plug in your console and charge it for a few minutes. If the battery is too old, it may start expanding and could potentially explode. If it starts to swell, you’ll have to order a replacement battery - which you can find below:
https://www.amazon.com/Game-Boy-Advance-...
Before beginning the replacement process, power off your console and unplug it from the outlet if it is plugged in.
Unscrew the screw on the battery compartment with a Phillips #00 screwdriver.
Open the battery compartment and remove the battery.
Remove the four 6.45 mm Tri-point Y00 screws from the corners of the device.
Remove the two 4.6 mm Tri-point Y00 screws from inside the battery compartment and game cartridge comparments.
Lift off the bottom cover to expose the motherboard.
Remove the three 4mm Phillips #00 screws from the motherboard.
Gently lift up the motherboard and remove the ribbon cable by gently pulling the two clips on the side up and towards the cable.
Remove the small Phillips #00 screw hidden underneath the ribbon cable. It holds the hinge cover of the top screen together.
Remove the hinges from the original shell. This is the most difficult step, as it requires a lot of force to remove the hinges.
Apply pressure with the pointed end of a spudger from the inside, pushing out with plenty of force. The hinges will likely fly out of the shell a few feet; this is normal.
Once the hinges are removed, remove the caps on the end of each hinge.
Reinsert the ribbon cable into the motherboard and lock it into place.
Guide the motherboard into the new case and screw it down with the three 4mm Phillips #00 screws.
Install the square, threaded washer on the back of the shell. This is where the battery compartment's screw gets held, so it is important!
Rehousing your GBA SP can be a fun project! It doesn’t take very long, and once you’re done you’ll have a fun new customized console! The ease of difficulty and ability to express yourself both make this project well worth attempting.
