This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Huawei P20 Pro Rear Camera Lens Replacement
    1. Huawei P20 Pro Rear Camera Lens Replacement, Rear Camera Lens: step 1, image 1 of 1
      • To replace the Huawei P20 Pro camera lens, place your phone on a clean, well-lit work surface. Wear safety glasses to protect your eyes.
      Ask FixBot
    2. Huawei P20 Pro Rear Camera Lens Replacement: step 2, image 1 of 2 Huawei P20 Pro Rear Camera Lens Replacement: step 2, image 2 of 2
      • Carefully remove the small pieces of broken glass using straight precision tweezers. You can slightly heat the area with a hair dryer to make it easier to remove.
      Ask FixBot
    3. Huawei P20 Pro Rear Camera Lens Replacement: step 3, image 1 of 1
      • Once the area is well cleaned, apply 2 dots of B7000 glue to the back and at each end of the new lens, or place 2 double-sided adhesive strips.
      • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
      Ask FixBot
    4. Huawei P20 Pro Rear Camera Lens Replacement: step 4, image 1 of 1
      • All done! You can take pictures again like you were able to do before.
      Ask FixBot
After replacing the camera lens, clean it with a dry microfiber cloth.
20 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
cPix
4,264 Reputation
8 Guides authored
2 Guide Comments
Tuto très bien expliquer je vais pouvoir maintenant reprendre de belles photos grâce à vous. Merci
Ace Ace - Reply Share
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
256 - Reply Share
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 108
All Time: 60,877
