Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
This teardown is not a repair guide. To repair your Nintendo DSi XL, use our service manual.
  1. Nintendo DSi XL Wi-fi Board Teardown, Nintendo DSi XL Wi-fi Board Teardown: step 1, image 1 of 2 Nintendo DSi XL Wi-fi Board Teardown, Nintendo DSi XL Wi-fi Board Teardown: step 1, image 2 of 2
    • Remove the two screws at the place of the battery under the Dsi Xl.
    • Lift the protector from the battery.
  2. Nintendo DSi XL Wi-fi Board Teardown: step 2, image 1 of 1
    • Take the battery off the Dsi Xl.
  3. Nintendo DSi XL Wi-fi Board Teardown: step 3, image 1 of 2 Nintendo DSi XL Wi-fi Board Teardown: step 3, image 2 of 2
    • Remove the rubber blocking the screws on the Dsi Xl with a push pin don't hesitate about it.
  4. Nintendo DSi XL Wi-fi Board Teardown: step 4, image 1 of 1
    • Remove the presenting screws in order to take the bottom part of the Dsi Xl off.
    • x4 silver 5.33m screws
    • x2 black 5.3m screws
    • x1 black 2.5m screw
  5. Nintendo DSi XL Wi-fi Board Teardown: step 5, image 1 of 2 Nintendo DSi XL Wi-fi Board Teardown: step 5, image 2 of 2
    • Turn the Dsi Xl over & open it.
    • Insert the spudger (or anything similar to it)between the uper and lower part of the case at the left or right corner it doesn't really matter.
    • Keep on doing the same around the case.
  6. Nintendo DSi XL Wi-fi Board Teardown: step 6, image 1 of 3 Nintendo DSi XL Wi-fi Board Teardown: step 6, image 2 of 3 Nintendo DSi XL Wi-fi Board Teardown: step 6, image 3 of 3
    • Using your hands unconnect the connectors from both sides ( you can always put them back.)
  7. Nintendo DSi XL Wi-fi Board Teardown: step 7, image 1 of 3 Nintendo DSi XL Wi-fi Board Teardown: step 7, image 2 of 3 Nintendo DSi XL Wi-fi Board Teardown: step 7, image 3 of 3
    • Lift the Wi-fi Board off of its socket.(you can also put this back.)
  8. Nintendo DSi XL Wi-fi Board Teardown: step 8, image 1 of 2 Nintendo DSi XL Wi-fi Board Teardown: step 8, image 2 of 2
    • Pull off the Wi-fi cable from The Wi-fi Board.
    • Careful while this process in which this peice can easily rip off.
    • Finally you've finished and you have Dsi Xl Wi-fi Board:)
Gabriel Rendon
151 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 7
All Time: 245
