Installing Nintendo DSi XL Wi-Fi Board
  1. Installing Nintendo DSi XL Wi-Fi Board, Battery: step 1, image 1 of 2 Installing Nintendo DSi XL Wi-Fi Board, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Installing Nintendo DSi XL Wi-Fi Board: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Installing Nintendo DSi XL Wi-Fi Board, Lower Case: step 3, image 1 of 3 Installing Nintendo DSi XL Wi-Fi Board, Lower Case: step 3, image 2 of 3 Installing Nintendo DSi XL Wi-Fi Board, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Installing Nintendo DSi XL Wi-Fi Board: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Installing Nintendo DSi XL Wi-Fi Board: step 5, image 1 of 3 Installing Nintendo DSi XL Wi-Fi Board: step 5, image 2 of 3 Installing Nintendo DSi XL Wi-Fi Board: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Installing Nintendo DSi XL Wi-Fi Board: step 6, image 1 of 2 Installing Nintendo DSi XL Wi-Fi Board: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Installing Nintendo DSi XL Wi-Fi Board: step 7, image 1 of 2 Installing Nintendo DSi XL Wi-Fi Board: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Installing Nintendo DSi XL Wi-Fi Board, Wi-Fi Board: step 8, image 1 of 2 Installing Nintendo DSi XL Wi-Fi Board, Wi-Fi Board: step 8, image 2 of 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Installing Nintendo DSi XL Wi-Fi Board: step 9, image 1 of 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
Brett Hartt
127,920 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,146 Guides authored
Past 24 Hours: 11
Past 7 Days: 30
Past 30 Days: 77
All Time: 13,433
