Installing Nintendo DSi XL Touchscreen
  1. Installing Nintendo DSi XL Touchscreen, Battery: step 1, image 1 of 2 Installing Nintendo DSi XL Touchscreen, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Installing Nintendo DSi XL Touchscreen: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Installing Nintendo DSi XL Touchscreen, Lower Case: step 3, image 1 of 3 Installing Nintendo DSi XL Touchscreen, Lower Case: step 3, image 2 of 3 Installing Nintendo DSi XL Touchscreen, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Installing Nintendo DSi XL Touchscreen: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Installing Nintendo DSi XL Touchscreen: step 5, image 1 of 3 Installing Nintendo DSi XL Touchscreen: step 5, image 2 of 3 Installing Nintendo DSi XL Touchscreen: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Installing Nintendo DSi XL Touchscreen: step 6, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Installing Nintendo DSi XL Touchscreen: step 7, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Installing Nintendo DSi XL Touchscreen, Wi-Fi Board: step 8, image 1 of 2 Installing Nintendo DSi XL Touchscreen, Wi-Fi Board: step 8, image 2 of 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Installing Nintendo DSi XL Touchscreen: step 9, image 1 of 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Installing Nintendo DSi XL Touchscreen, Motherboard: step 10, image 1 of 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Installing Nintendo DSi XL Touchscreen: step 11, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 11, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Installing Nintendo DSi XL Touchscreen: step 12, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 12, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Installing Nintendo DSi XL Touchscreen: step 13, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 13, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Installing Nintendo DSi XL Touchscreen: step 14, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 14, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Installing Nintendo DSi XL Touchscreen: step 15, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 15, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Installing Nintendo DSi XL Touchscreen: step 16, image 1 of 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Installing Nintendo DSi XL Touchscreen: step 17, image 1 of 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Installing Nintendo DSi XL Touchscreen: step 18, image 1 of 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Installing Nintendo DSi XL Touchscreen: step 19, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 19, image 2 of 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Installing Nintendo DSi XL Touchscreen: step 20, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 20, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  21. Installing Nintendo DSi XL Touchscreen, Lower Display Assembly: step 21, image 1 of 2 Installing Nintendo DSi XL Touchscreen, Lower Display Assembly: step 21, image 2 of 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Installing Nintendo DSi XL Touchscreen, Lower LCD: step 22, image 1 of 2 Installing Nintendo DSi XL Touchscreen, Lower LCD: step 22, image 2 of 2
    • Insert a spudger between the touchscreen and top right corner of the display.
    • Slide the spudger down the right side of the display to free the edge of the touchscreen.
  23. Installing Nintendo DSi XL Touchscreen: step 23, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 23, image 2 of 2
    • Continue around the bottom right corner of the display with the spudger.
    • Slide the spudger along the bottom edge of the touchscreen to separate it from the display.
  24. Installing Nintendo DSi XL Touchscreen: step 24, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 24, image 2 of 2
    • Continue around the bottom left corner of the display with a spudger.
    • Slide the spudger along the left edge of the touchscreen to remove it from the display.
  25. Installing Nintendo DSi XL Touchscreen: step 25, image 1 of 2 Installing Nintendo DSi XL Touchscreen: step 25, image 2 of 2
    • With three sides freed, remove the touchscreen from the lower display.
David Hodson
150,791 Reputation
127 Guides authored
Past 24 Hours: 12
Past 7 Days: 100
Past 30 Days: 439
All Time: 43,195
