Installing Nintendo DSi XL Rear Bezel
  1. Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 1, image 1 of 3 Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 1, image 2 of 3 Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 1, image 3 of 3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Installing Nintendo DSi XL Rear Bezel: step 2, image 1 of 1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Installing Nintendo DSi XL Rear Bezel: step 3, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 3, image 2 of 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Installing Nintendo DSi XL Rear Bezel: step 4, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 4, image 2 of 2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. Installing Nintendo DSi XL Rear Bezel: step 5, image 1 of 1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Installing Nintendo DSi XL Rear Bezel: step 6, image 1 of 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Installing Nintendo DSi XL Rear Bezel: step 7, image 1 of 1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Matthew Newsom
39,524 Reputation
67 Guides authored
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 38
All Time: 5,085
