Installing Nintendo DSi XL Rear Bezel
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing Nintendo DSi XL Rear Bezel, Battery: step 1, image 1 of 2 Installing Nintendo DSi XL Rear Bezel, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Installing Nintendo DSi XL Rear Bezel: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Installing Nintendo DSi XL Rear Bezel, Lower Case: step 3, image 1 of 3 Installing Nintendo DSi XL Rear Bezel, Lower Case: step 3, image 2 of 3 Installing Nintendo DSi XL Rear Bezel, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Installing Nintendo DSi XL Rear Bezel: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Installing Nintendo DSi XL Rear Bezel: step 5, image 1 of 3 Installing Nintendo DSi XL Rear Bezel: step 5, image 2 of 3 Installing Nintendo DSi XL Rear Bezel: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Installing Nintendo DSi XL Rear Bezel: step 6, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Installing Nintendo DSi XL Rear Bezel: step 7, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Installing Nintendo DSi XL Rear Bezel, Wi-Fi Board: step 8, image 1 of 2 Installing Nintendo DSi XL Rear Bezel, Wi-Fi Board: step 8, image 2 of 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Installing Nintendo DSi XL Rear Bezel: step 9, image 1 of 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Installing Nintendo DSi XL Rear Bezel, Motherboard: step 10, image 1 of 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Installing Nintendo DSi XL Rear Bezel: step 11, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 11, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Installing Nintendo DSi XL Rear Bezel: step 12, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 12, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Installing Nintendo DSi XL Rear Bezel: step 13, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 13, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Installing Nintendo DSi XL Rear Bezel: step 14, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 14, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Installing Nintendo DSi XL Rear Bezel: step 15, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 15, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Installing Nintendo DSi XL Rear Bezel: step 16, image 1 of 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Installing Nintendo DSi XL Rear Bezel: step 17, image 1 of 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Installing Nintendo DSi XL Rear Bezel: step 18, image 1 of 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Installing Nintendo DSi XL Rear Bezel: step 19, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 19, image 2 of 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Installing Nintendo DSi XL Rear Bezel: step 20, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 20, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  21. Installing Nintendo DSi XL Rear Bezel, Lower Display Assembly: step 21, image 1 of 2 Installing Nintendo DSi XL Rear Bezel, Lower Display Assembly: step 21, image 2 of 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 22, image 1 of 3 Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 22, image 2 of 3 Installing Nintendo DSi XL Rear Bezel, Rear Bezel: step 22, image 3 of 3
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  23. Installing Nintendo DSi XL Rear Bezel: step 23, image 1 of 1
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  24. Installing Nintendo DSi XL Rear Bezel: step 24, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 24, image 2 of 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  25. Installing Nintendo DSi XL Rear Bezel: step 25, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 25, image 2 of 2
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  26. Installing Nintendo DSi XL Rear Bezel: step 26, image 1 of 2 Installing Nintendo DSi XL Rear Bezel: step 26, image 2 of 2
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  27. Installing Nintendo DSi XL Rear Bezel: step 27, image 1 of 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  28. Installing Nintendo DSi XL Rear Bezel: step 28, image 1 of 1
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Brett Hartt
127,926 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,222 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 603
