Installing Nintendo DSi XL Lower Case
  1. Installing Nintendo DSi XL Lower Case, Battery: step 1, image 1 of 2 Installing Nintendo DSi XL Lower Case, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Installing Nintendo DSi XL Lower Case: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Installing Nintendo DSi XL Lower Case, Lower Case: step 3, image 1 of 3 Installing Nintendo DSi XL Lower Case, Lower Case: step 3, image 2 of 3 Installing Nintendo DSi XL Lower Case, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Installing Nintendo DSi XL Lower Case: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Installing Nintendo DSi XL Lower Case: step 5, image 1 of 3 Installing Nintendo DSi XL Lower Case: step 5, image 2 of 3 Installing Nintendo DSi XL Lower Case: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Installing Nintendo DSi XL Lower Case: step 6, image 1 of 2 Installing Nintendo DSi XL Lower Case: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Installing Nintendo DSi XL Lower Case: step 7, image 1 of 2 Installing Nintendo DSi XL Lower Case: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
David Hodson
150,556 Reputation
127 Guides authored
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 90
All Time: 8,621
