Introduction
Use this guide to replace the lower case assembly, including the trigger buttons, SD slot, and stylus holder.
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips screws.
One 2.7 mm Phillips screw.
Insert the flat screwdriver in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the flat screwdriver along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the flat screwdriver around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard with the flat edge of a screwdriver.
once the cable, highlighted in the orange box, is completely removed then you may take off the entire outer casing.
