Installing Nintendo DS Lite Wi-Fi Board
  1. Installing Nintendo DS Lite Wi-Fi Board, Battery: step 1, image 1 of 2 Installing Nintendo DS Lite Wi-Fi Board, Battery: step 1, image 2 of 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Installing Nintendo DS Lite Wi-Fi Board: step 2, image 1 of 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Installing Nintendo DS Lite Wi-Fi Board, Lower Case: step 3, image 1 of 2 Installing Nintendo DS Lite Wi-Fi Board, Lower Case: step 3, image 2 of 2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Installing Nintendo DS Lite Wi-Fi Board: step 4, image 1 of 1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
  5. Installing Nintendo DS Lite Wi-Fi Board: step 5, image 1 of 3 Installing Nintendo DS Lite Wi-Fi Board: step 5, image 2 of 3 Installing Nintendo DS Lite Wi-Fi Board: step 5, image 3 of 3
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Installing Nintendo DS Lite Wi-Fi Board: step 6, image 1 of 1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Installing Nintendo DS Lite Wi-Fi Board, Trigger Buttons: step 7, image 1 of 2 Installing Nintendo DS Lite Wi-Fi Board, Trigger Buttons: step 7, image 2 of 2
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
  8. Installing Nintendo DS Lite Wi-Fi Board, Wi-Fi Board: step 8, image 1 of 1
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Installing Nintendo DS Lite Wi-Fi Board: step 9, image 1 of 1
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
  10. Installing Nintendo DS Lite Wi-Fi Board: step 10, image 1 of 1
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
Matthew Newsom
39,592 Reputation
67 Guides authored
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 140
All Time: 15,884
