This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Nintendo DS Lite Power Button PCB
Views: 1.5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
67
Past 30 Days:
337
All Time:
1,466
Comments: 68
68 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to replace the part of the power button that is soldered to the PCB. If you don't have any soldering skills yet, here is a tutorial .
Parts
Tools
    1. Nintendo DS Lite Power Button PCB, Battery: step 1, image 1 of 2 Nintendo DS Lite Power Button PCB, Battery: step 1, image 2 of 2
      • Unscrew the Phillips screw securing the battery cover to the lower case.
      • The screw remains captive to the battery cover.
      • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
      Ask FixBot
    2. Nintendo DS Lite Power Button PCB: step 2, image 1 of 1
      • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
      • Remove the battery from the DS Lite.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Lower Case: step 3, image 1 of 2 Nintendo DS Lite Power Button PCB, Lower Case: step 3, image 2 of 2
      • Use the tip of a spudger to pry both rubber feet off the DS Lite.
      Ask FixBot
    2. Nintendo DS Lite Power Button PCB: step 4, image 1 of 1
      • Remove the following screws securing the lower case to the body of the DS Lite:
      • Two 4.3 mm gold Phillips screws
      • One 3.9 mm black Tri-point screw
      • One 3.3 mm silver Phillips screw
      • Three 5.5 mm silver Tri-point screws
      Ask FixBot
    3. Nintendo DS Lite Power Button PCB: step 5, image 1 of 3 Nintendo DS Lite Power Button PCB: step 5, image 2 of 3 Nintendo DS Lite Power Button PCB: step 5, image 3 of 3
      • Remove the cover from the Game Pak slot before continuing.
      • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
      • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
      • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
      Ask FixBot
    4. Nintendo DS Lite Power Button PCB: step 6, image 1 of 1
      • Lift the lower case away from the rest of the DS Lite.
      • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
      • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Trigger Buttons: step 7, image 1 of 2 Nintendo DS Lite Power Button PCB, Trigger Buttons: step 7, image 2 of 2
      • Lift both trigger buttons out of the DS Lite.
      • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
      • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Wi-Fi Board: step 8, image 1 of 1
      • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
      Ask FixBot
    2. Nintendo DS Lite Power Button PCB: step 9, image 1 of 1
      • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
      Ask FixBot
    3. Nintendo DS Lite Power Button PCB: step 10, image 1 of 1
      • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
      • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
      • Remove the Wi-Fi board from the DS Lite.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Motherboard: step 11, image 1 of 1
      • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
      Ask FixBot
    2. Nintendo DS Lite Power Button PCB: step 12, image 1 of 3 Nintendo DS Lite Power Button PCB: step 12, image 2 of 3 Nintendo DS Lite Power Button PCB: step 12, image 3 of 3
      • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
      • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
      • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
      • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
      • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
      Ask FixBot
    3. Nintendo DS Lite Power Button PCB: step 13, image 1 of 2 Nintendo DS Lite Power Button PCB: step 13, image 2 of 2
      • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
      • Make sure you are flipping up the retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
      • Do not lift the flap more than 90 degrees, or you will break it off.
      Ask FixBot
    4. Nintendo DS Lite Power Button PCB: step 14, image 1 of 1
      • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
      Ask FixBot
    5. Nintendo DS Lite Power Button PCB: step 15, image 1 of 1
      • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
      • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
      Ask FixBot
    6. Nintendo DS Lite Power Button PCB: step 16, image 1 of 2 Nintendo DS Lite Power Button PCB: step 16, image 2 of 2
      • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
      • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
      • Remove the motherboard from the DS Lite.
      • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Motherboard: step 17, image 1 of 1
      • Motherboard remains.
      Ask FixBot
    1. Nintendo DS Lite Power Button PCB, Power button: step 18, image 1 of 1
      • The power button is located in the upper right corner of the logic board, directly behind the right bumper.
      Ask FixBot
    2. Nintendo DS Lite Power Button PCB, Desoldering the power button: step 19, image 1 of 2 Nintendo DS Lite Power Button PCB, Desoldering the power button: step 19, image 2 of 2
      • The power button is attached to the PCB with six solder points. There are also two plastic pegs located underneath the power button.
      • To prepare, you should first add some fresh solder to each of the six solder joints.
      • To desolder, hold the desoldering wick between the solder joint and the soldering iron, and press the iron onto the wick for a few seconds until it turns silver.
      • You can use tweezers to check if the individual pins are properly desoldered. To do this, press the tweezers against the side of the pin and see if it moves.
      • It may not be possible to remove all the solder. However, once enough solder has been removed, you should be able to detach the switch from the PCB by using tweezers and applying some pressure toward the card reader.
      • It is also possible to desolder the switch using hot air.
      • While desoldering, take care not to desolder or damage any other components.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Sontha
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 67
Past 30 Days: 337
All Time: 1,466
