Nintendo DS Back Panel Replacement
  1. Nintendo DS Back Panel Replacement, Battery: step 1, image 1 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 2 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 3 of 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Back Panel Replacement: step 2, image 1 of 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Back Panel Replacement: step 3, image 1 of 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Back Panel Replacement, Back Panel: step 4, image 1 of 1
    • Remove the seven Y00 screws located on the back.
    • It might be helpful to remove the strap from the hole to access the top left screw.
  5. Nintendo DS Back Panel Replacement: step 5, image 1 of 3 Nintendo DS Back Panel Replacement: step 5, image 2 of 3 Nintendo DS Back Panel Replacement: step 5, image 3 of 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
dnguye26
694 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
28 Guides authored
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 116
All Time: 17,605
