Snapfon ezOne Speaker Replacement
    1. Snapfon ezOne Speaker Replacement, Remove the battery cover: step 1, image 1 of 1
      • Turn off the phone to prevent data loss.
      • Press and slide the battery out to remove it.
      • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
      Ask FixBot
    2. Snapfon ezOne Speaker Replacement, Remove the battery: step 2, image 1 of 1
      • Pry the battery out with your thumb or the iFixit opening tool.
      • Make sure to properly dispose of the old battery at a recycling center.
      Ask FixBot
    1. Snapfon ezOne Speaker Replacement, Removing the plastic inserts: step 3, image 1 of 2 Snapfon ezOne Speaker Replacement, Removing the plastic inserts: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the four rubber inserts from the screw holes using a pair of tweezers.
      Ask FixBot
    2. Snapfon ezOne Speaker Replacement, Remove the shield screws: step 4, image 1 of 3 Snapfon ezOne Speaker Replacement, Remove the shield screws: step 4, image 2 of 3 Snapfon ezOne Speaker Replacement, Remove the shield screws: step 4, image 3 of 3
      • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
      Ask FixBot
    3. Snapfon ezOne Speaker Replacement, Separate the case: step 5, image 1 of 3 Snapfon ezOne Speaker Replacement, Separate the case: step 5, image 2 of 3 Snapfon ezOne Speaker Replacement, Separate the case: step 5, image 3 of 3
      • Separate the front case from the back case.
      • Remove the metal bumper from the front case’s perimeter.
      Ask FixBot
    4. Snapfon ezOne Speaker Replacement, Remove the volume slider: step 6, image 1 of 1
      • Pry the volume slider button out with tweezers.
      • The volume slider button may fall out during the separation of the front and back cases. This is OK.
      Ask FixBot
    5. Snapfon ezOne Speaker Replacement, Remove the motherboard: step 7, image 1 of 3 Snapfon ezOne Speaker Replacement, Remove the motherboard: step 7, image 2 of 3 Snapfon ezOne Speaker Replacement, Remove the motherboard: step 7, image 3 of 3
      • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
      • The last picture is a view of the back of the circuit board.
      Ask FixBot
    1. Snapfon ezOne Speaker Replacement, Speaker: step 8, image 1 of 2 Snapfon ezOne Speaker Replacement, Speaker: step 8, image 2 of 2
      Buy
      • Remove SOS button from circuit board with tweezers.
      Ask FixBot
    2. Snapfon ezOne Speaker Replacement: step 9, image 1 of 3 Snapfon ezOne Speaker Replacement: step 9, image 2 of 3 Snapfon ezOne Speaker Replacement: step 9, image 3 of 3
      • Pull black casing from the circuit board with fingers.
      • The black casing will not be able to be fully removed at this point
      • To fully remove the black casing, desolder the SOS button cable from the circuit board with a soldering iron.
      • The solder iron creates high temperatures that may cause bodily harm.
      • Once the black casing is removed, the speaker will now be exposed.
      Ask FixBot
    3. Snapfon ezOne Speaker Replacement: step 10, image 1 of 3 Snapfon ezOne Speaker Replacement: step 10, image 2 of 3 Snapfon ezOne Speaker Replacement: step 10, image 3 of 3
      • With the plastic opening tools, pry off the speaker from the circuit board.
      Ask FixBot
    4. Snapfon ezOne Speaker Replacement: step 11, image 1 of 2 Snapfon ezOne Speaker Replacement: step 11, image 2 of 2
      • Desolder the speaker cables from the base of the circuit board with the soldering iron.
      • The soldering iron creates high temperatures that may cause bodily harm.
      • Melt the new speaker wires to the circuit board with the soldering iron.
      Ask FixBot
John Bender
818 Reputation
8 Guides authored
Clemson, Team 6-5, Benson Spring 2014 Member of Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 44
All Time: 699
