Introduction
This guide will show how to replace the Nintendo 64 motherboard.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
I have noticed this is not in Australian Pal versions of the N64.
at First i thought i was missing a bit on my N64 and now have looked a second one and its also not there.
Remove the four screws indicated using the #1 Phillips screwdriver.
36 other people completed this guide.
