Introduction
Go to step 1 ↓
Provided is an exploded view of the TI-92 calculator. All dis-assembled components are the back-side of the parts.
Tools
This teardown is not a repair guide. To repair your Texas Instruments TI-92, use our service manual.
    1. Texas Instruments TI-92 Teardown, Texas Instruments TI-92 Teardown: step 1, image 1 of 1
      • Remove the protective cover. This will easily unsnap from the main body.
      Ask FixBot
    2. Texas Instruments TI-92 Teardown: step 2, image 1 of 1
      • Slide the tab located at the top of the calculator to the unlocked position.
      Ask FixBot
    3. Texas Instruments TI-92 Teardown: step 3, image 1 of 1
      • Slide the back cover down, and then pull the back plate away from the calculator.
      Ask FixBot
    4. Texas Instruments TI-92 Teardown: step 4, image 1 of 1
      • Unscrew the back-up battery cover. (1 screw)
      Ask FixBot
    5. Texas Instruments TI-92 Teardown: step 5, image 1 of 1
      • Remove all visible screws.
      • Note that there are more screws than shown in this picture (16 in total). You MUST remove them ALL.
      Ask FixBot
    6. Texas Instruments TI-92 Teardown: step 6, image 1 of 1
      • Keeping the front faceplate FACE DOWN on the work surface, lift the circuit board AND the plastic backing up and away from the faceplate.
      Ask FixBot
    7. Texas Instruments TI-92 Teardown: step 7, image 1 of 1
      • These two components are loosely attached by the rectangular module just below the back-up battery.
      Ask FixBot
    8. Texas Instruments TI-92 Teardown: step 8, image 1 of 1
      • The warning label next to this module reads "Do not remove the rectangular module located under the test access panel as it is required for proper product operation!"
      Ask FixBot
    9. Texas Instruments TI-92 Teardown: step 9, image 1 of 1
      • The rubber mat in back of the faceplate may be removed, exposing all 77 individual plastic keys.
      • CAUTION: These keys are loosely held in by gravity and will fall out if the faceplate is tilted to any extreme.
      Ask FixBot
    10. Texas Instruments TI-92 Teardown: step 10, image 1 of 1
      • The device has now been separated into as many component parts as intended by the manufacturer.
      Ask FixBot
Daniel Maldonado
264 Reputation
9 Guides authored
Cal Poly, Team 15-51, Garner Spring 2010 Member of Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 56
All Time: 9,717
