RIM BlackBerry 7510 Disassembly
Views: 3.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
36
All Time:
3,136
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show how to disassemble the Blackberry.
Tools
    1. RIM BlackBerry 7510 Disassembly, RIM BlackBerry 7510: step 1, image 1 of 1
      • Remove the back cover exposing the battery, and remove the battery.
      Ask FixBot
    2. RIM BlackBerry 7510 Disassembly: step 2, image 1 of 1
      • Remove the six screws with the screwdriver using the T-5 tip.
      Ask FixBot
    3. RIM BlackBerry 7510 Disassembly: step 3, image 1 of 1
      • Pry open back cover
      Ask FixBot
    4. RIM BlackBerry 7510 Disassembly: step 4, image 1 of 1
      • Lift off the back cover.
      Ask FixBot
    5. RIM BlackBerry 7510 Disassembly: step 5, image 1 of 1
      • Unscrew the two screws with a T-6 screwdriver head
      Ask FixBot
    6. RIM BlackBerry 7510 Disassembly: step 6, image 1 of 1
      • Remove chip
      Ask FixBot
    7. RIM BlackBerry 7510 Disassembly: step 7, image 1 of 1
      • Unscrew to remove the back plate
      Ask FixBot
    8. RIM BlackBerry 7510 Disassembly: step 8, image 1 of 1
      • Carefully pry off back plate
      Ask FixBot
    9. RIM BlackBerry 7510 Disassembly: step 9, image 1 of 1
      • Take off front cover and keypad
      Ask FixBot
    10. RIM BlackBerry 7510 Disassembly: step 10, image 1 of 1
      • Remove one screw in the front.
      Ask FixBot
    11. RIM BlackBerry 7510 Disassembly: step 11, image 1 of 1
      • Pry the two parts apart.
      Ask FixBot
    12. RIM BlackBerry 7510 Disassembly: step 12, image 1 of 1
      • The screen is now apart from the phone.
      Ask FixBot
    13. RIM BlackBerry 7510 Disassembly: step 13, image 1 of 1
      • Using the Philips screwdriver unscrew center screw.
      Ask FixBot
    14. RIM BlackBerry 7510 Disassembly: step 14, image 1 of 1
      • The final two parts now come apart.
      Ask FixBot
    15. RIM BlackBerry 7510 Disassembly: step 15, image 1 of 1
      • The phone is now completely disassembled. Handle back with care shown piece comes right off.
      Ask FixBot
    16. RIM BlackBerry 7510 Disassembly: step 16, image 1 of 1
      • Your blackberry has been fully disassembled.
      Ask FixBot
Laura Yanez
2 Reputation
1 Guide authored
Cal Poly, Team 14-44, Regan Winter 2010 Member of Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 36
All Time: 3,136
