Kano Computer Kit Complete Display Board Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
79
All Time:
2,273
Comments: 6
6 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If your computer continuously gives off a burning odor or it keeps crashing after bugs have supposedly been fixed, chances are you need to replace your Display driver. This guide will show you exactly how to do that through simple, easy to follow steps with pictures to help you along. The only tool you will be needing is a Phillips #1 Screwdriver for the four 8.5mm screws to complete this guide.
Tools
    1. Kano Computer Kit Complete Display Board Replacement, Display Board: step 1, image 1 of 2 Kano Computer Kit Complete Display Board Replacement, Display Board: step 1, image 2 of 2
      • Take off the clear backing of the computer and set it aside.
      • The Display board is located in the top right corner of the case.
      Ask FixBot
    2. Kano Computer Kit Complete Display Board Replacement: step 2, image 1 of 2 Kano Computer Kit Complete Display Board Replacement: step 2, image 2 of 2
      • Always disconnect the battery before performing repairs.
      • Remove the power cable (Circled in red) from the board.
      Ask FixBot
    3. Kano Computer Kit Complete Display Board Replacement: step 3, image 1 of 3 Kano Computer Kit Complete Display Board Replacement: step 3, image 2 of 3 Kano Computer Kit Complete Display Board Replacement: step 3, image 3 of 3
      • Unplug the HDMI cable (Circled in Yellow) from the board
      Ask FixBot
    4. Kano Computer Kit Complete Display Board Replacement: step 4, image 1 of 1
      • Unscrew the four 8.5mm screws with your Phillips #1 Screwdriver.
      Ask FixBot
    5. Kano Computer Kit Complete Display Board Replacement: step 5, image 1 of 2 Kano Computer Kit Complete Display Board Replacement: step 5, image 2 of 2
      • Lift the board off the back of the screen.
      • Be gentle as there is a ribbon cable on the underside that will prevent the board from being removed completely.
      Ask FixBot
    6. Kano Computer Kit Complete Display Board Replacement: step 6, image 1 of 2 Kano Computer Kit Complete Display Board Replacement: step 6, image 2 of 2
      • Disconnect the white ribbon cable that you find underneath the board.
      • Be careful; it will take some force.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 79
All Time: 2,273
