Introduction
This fix is necessary for the owners of N64 controllers when the joystick becomes too loose over time. If the joystick of a controller is loose, game play becomes difficult. Conditions for this fix include: a flat surface, plenty of light, and a method for keeping track of individual components of the controller. Practice caution when using the knife in this fix.
Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
Remove the back panel from the controller.
Remove the screws (4.8 mm Phillips head) from the back of the white joystick box.
Remove the back panel of the white joystick box.
Remove the screw (4.8 mm Philips head) from the back of the joystick box.
Remove the joystick box from the controller.
Press the epoxy into the center of the bowl with your finger and add a drop of water into the bowl.
Place a marble into the bowl and use a push-twist motion to form the epoxy into the shape of the bowl.
Cut the edges of the excess epoxy with the exacto knife.
Repeat steps 8 and 9 until no excess epoxy is left.
