Nintendo 64 Controller Joystick Repair
  1. Nintendo 64 Controller Joystick Repair, Nintendo 64 Controller Joystick Repair: step 1, image 1 of 1
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
  2. Nintendo 64 Controller Joystick Repair: step 2, image 1 of 1
    • Detach the two wired connections from the small, white box.
  3. Nintendo 64 Controller Joystick Repair: step 3, image 1 of 1
    • Remove the screws (4.8 mm Phillips head) from the back of the white joystick box.
    • Remove the back panel of the white joystick box.
    • Note: There are many small plastic components loose in this box, so be careful not to lose these.
  4. Nintendo 64 Controller Joystick Repair: step 4, image 1 of 1
    • Remove the screw (4.8 mm Philips head) from the back of the joystick box.
    • Remove the joystick box from the controller.
  5. Nintendo 64 Controller Joystick Repair: step 5, image 1 of 1
    • Use a cleaning cloth to remove residue and dirt from any components.
  6. Nintendo 64 Controller Joystick Repair: step 6, image 1 of 1
    • Free the small, white bowl from its connections to the controller.
    • Note: Remember the order in which each piece was removed.
  7. Nintendo 64 Controller Joystick Repair: step 7, image 1 of 1
    • Pinch off a small piece of epoxy and kneed it in your hand until a uniform color is reached.
  8. Nintendo 64 Controller Joystick Repair: step 8, image 1 of 1
    • Press the epoxy into the center of the bowl with your finger and add a drop of water into the bowl.
  9. Nintendo 64 Controller Joystick Repair: step 9, image 1 of 1
    • Place a marble into the bowl and use a push-twist motion to form the epoxy into the shape of the bowl.
    • Excess epoxy will rise above the bowl.
  10. Nintendo 64 Controller Joystick Repair: step 10, image 1 of 1
    • Cut the edges of the excess epoxy with the exacto knife.
    • Repeat steps 8 and 9 until no excess epoxy is left.
  11. Nintendo 64 Controller Joystick Repair: step 11, image 1 of 1
    • Let the epoxy sit and dry for 30 minutes or until the epoxy is hardened.
  12. Nintendo 64 Controller Joystick Repair: step 12, image 1 of 1
    • Add a small coat of grease on top of the epoxy with your applicator.
  13. Nintendo 64 Controller Joystick Repair: step 13, image 1 of 1
    • Apply grease to the bottom of the joystick (the area circled in red)
  14. Nintendo 64 Controller Joystick Repair: step 14, image 1 of 1
    • Reverse these steps to reassemble the controller.
    • You may want to test the joystick stiffness before reassembling the controller.
Brittany Slindee
345 Reputation
1 Guide authored
Past 24 Hours: 10
Past 7 Days: 112
Past 30 Days: 440
All Time: 41,969
