Disassembling Compaq Mini 110 Wireless Module
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
84
All Time:
4,673
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Wireless module in your way? Move it out!
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Disassembling Compaq Mini 110 Wireless Module, Battery: step 1, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 2, image 1 of 3 Disassembling Compaq Mini 110 Wireless Module: step 2, image 2 of 3 Disassembling Compaq Mini 110 Wireless Module: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Wireless Module, RAM: step 3, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Wireless Module, Keyboard: step 5, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 6, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Wireless Module: step 7, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Disassembling Compaq Mini 110 Wireless Module: step 8, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Wireless Module, Hard Drive: step 9, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 10, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module: step 10, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Wireless Module, Top Cover: step 11, image 1 of 1
      • Remove the eight screws that are from the plastic top cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 12, image 1 of 3 Disassembling Compaq Mini 110 Wireless Module: step 12, image 2 of 3 Disassembling Compaq Mini 110 Wireless Module: step 12, image 3 of 3
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Wireless Module: step 13, image 1 of 2 Disassembling Compaq Mini 110 Wireless Module: step 13, image 2 of 2
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Wireless Module, Wireless Module: step 14, image 1 of 1
      • Remove the two screws holding the module in place.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Wireless Module: step 15, image 1 of 1
      • Detach the two wires.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Wireless Module: step 16, image 1 of 1
      • Just pull it out.
      Ask FixBot
alea
1,441 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 84
All Time: 4,673
