Nintendo 64 Controller Action Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
68
All Time:
408
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your N64 controller (model NUS-005) buttons feel less responsive, this guide will show you how to replace the N64 action buttons (A, B, and the arrows). The N64 buttons are used to interact with the game and are needed to perform actions. Over a long period of usage time, the N64 controller will become less responsive. This is due to the rubber contact membrane (the rubber layer that's on the buttons) wearing off and needing to be replaced. Replacing your buttons and rubber content membrane will fix the unresponsive issue and make it feel like a brand new controller.
Tools
    1. Nintendo 64 Controller Action Buttons Replacement, Action Buttons: step 1, image 1 of 3 Nintendo 64 Controller Action Buttons Replacement, Action Buttons: step 1, image 2 of 3 Nintendo 64 Controller Action Buttons Replacement, Action Buttons: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the screws from the backside of the controller.
      • Pull the back shell away from the rest of the controller.
      Ask FixBot
    2. Nintendo 64 Controller Action Buttons Replacement: step 2, image 1 of 2 Nintendo 64 Controller Action Buttons Replacement: step 2, image 2 of 2
      • Remove the shoulder buttons.
      • Unhook the cable.
      Ask FixBot
    3. Nintendo 64 Controller Action Buttons Replacement: step 3, image 1 of 3 Nintendo 64 Controller Action Buttons Replacement: step 3, image 2 of 3 Nintendo 64 Controller Action Buttons Replacement: step 3, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the three screws from the joystick.
      • Carefully remove the whole motherboard.
      Ask FixBot
    4. Nintendo 64 Controller Action Buttons Replacement: step 4, image 1 of 3 Nintendo 64 Controller Action Buttons Replacement: step 4, image 2 of 3 Nintendo 64 Controller Action Buttons Replacement: step 4, image 3 of 3
      • Slowly remove the rubber contact membranes and buttons.
      Ask FixBot
    5. Nintendo 64 Controller Action Buttons Replacement: step 5, image 1 of 3 Nintendo 64 Controller Action Buttons Replacement: step 5, image 2 of 3 Nintendo 64 Controller Action Buttons Replacement: step 5, image 3 of 3
      • Carefully insert new buttons that you wish to replace.
      • Make sure they are lined up correctly.
      Ask FixBot
    6. Nintendo 64 Controller Action Buttons Replacement: step 6, image 1 of 2 Nintendo 64 Controller Action Buttons Replacement: step 6, image 2 of 2
      • Re-attach the rubber contact membranes over the buttons.
      • Make sure it is lined up and the buttons are firm.
      Ask FixBot
    7. Nintendo 64 Controller Action Buttons Replacement: step 7, image 1 of 2 Nintendo 64 Controller Action Buttons Replacement: step 7, image 2 of 2
      • Line up the motherboard black in place.
      • Wrap the cable and insert it back into the little slot.
      • Insert the shoulder buttons back in place.
      Ask FixBot
    8. Nintendo 64 Controller Action Buttons Replacement: step 8, image 1 of 2 Nintendo 64 Controller Action Buttons Replacement: step 8, image 2 of 2
      • Line up the joystick with the screw holes.
      • Using the screws that were put to the side, screw in the joystick.
      Ask FixBot
    9. Nintendo 64 Controller Action Buttons Replacement: step 9, image 1 of 3 Nintendo 64 Controller Action Buttons Replacement: step 9, image 2 of 3 Nintendo 64 Controller Action Buttons Replacement: step 9, image 3 of 3
      • Align the back shell with the screw holes.
      • Using the screws that were saved from step 1, screw them back in.
      Ask FixBot
To reassemble your device, follow these instructions in order
Andres Gutierrez
187 Reputation
1 Guide authored
CSU Los Angeles, Team 5-5, Grodsky Fall 2025 Member of CSU Los Angeles, Team 5-5, Grodsky Fall 2025
CSULA-GRODSKY-F25S5G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 68
All Time: 408
