Nintendo 3DS XL Upper LCD Display Replacement
  1. Nintendo 3DS XL Upper LCD Display Replacement, Battery: step 1, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement, Battery: step 1, image 2 of 2
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Upper LCD Display Replacement: step 2, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 2, image 2 of 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Upper LCD Display Replacement: step 3, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 3, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  4. Nintendo 3DS XL Upper LCD Display Replacement, Circle Pad Joystick: step 4, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement, Circle Pad Joystick: step 4, image 2 of 2
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Nintendo 3DS XL Upper LCD Display Replacement: step 5, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 5, image 2 of 2
    • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
  6. Nintendo 3DS XL Upper LCD Display Replacement: step 6, image 1 of 1
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
  7. Nintendo 3DS XL Upper LCD Display Replacement: step 7, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 7, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 7, image 3 of 3
    • Make sure the SD card has been removed. With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Nintendo 3DS XL Upper LCD Display Replacement: step 8, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 8, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 8, image 3 of 3
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. Nintendo 3DS XL Upper LCD Display Replacement: step 9, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 9, image 2 of 2
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the circle pad on the right side of the device.
    • Remove the two 7.5 mm screws on the upper left and the bottom right corners.
  10. Nintendo 3DS XL Upper LCD Display Replacement: step 10, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 10, image 2 of 2
    • Using a plastic opening tool pop off the circle pad joystick.
    • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
    • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
  11. Nintendo 3DS XL Upper LCD Display Replacement: step 11, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 11, image 2 of 2
    • Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
    • Remove the ribbon and circle pad joystick.
  12. Nintendo 3DS XL Upper LCD Display Replacement, IR Board: step 12, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement, IR Board: step 12, image 2 of 2
    • Locate the IR board located on the upper right side of the motherboard.
    • The IR board is installed upside-down in these photos by mistake. Installing it this way will result in your DS failing to start. Note the orientation of your IR board before you remove it, and reinstall it the same way.
    • Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
  13. Nintendo 3DS XL Upper LCD Display Replacement, Motherboard: step 13, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement, Motherboard: step 13, image 2 of 2
    • Using a plastic opening tool, pry off the Wi-Fi board.
    • The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
  14. Nintendo 3DS XL Upper LCD Display Replacement: step 14, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 14, image 2 of 2
    • Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
    • Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
  15. Nintendo 3DS XL Upper LCD Display Replacement: step 15, image 1 of 1
    • Using the flat head side of the spudger carefully lift up the flap that attaches the volume board ribbon to the motherboard.
    • Remove the volume board and set aside.
  16. Nintendo 3DS XL Upper LCD Display Replacement: step 16, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 16, image 2 of 2
    • Remove the black plastic pieces from the lower left and right hand corners with either your fingers or tweezers.
    • You can also remove these pieces easily by carefully lifting up the 3DS and holding it upside-down. They normally fall right out, but don't lose them!
  17. Nintendo 3DS XL Upper LCD Display Replacement: step 17, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 17, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 17, image 3 of 3
    • Using the flat head side of the spudger carefully lift up the flap that attaches the two smaller ribbons to the motherboard.
    • These flaps are located on the top right and bottom right side of the motherboard.
    • Remove the ribbons from the flap.
  18. Nintendo 3DS XL Upper LCD Display Replacement: step 18, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 18, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 18, image 3 of 3
    • Using the flat head side of the spudger carefully lift up the flaps that attach the wider ribbons to the motherboard.
    • For the wider ribbons make sure to lift the flaps from the white side.
    • Remove the ribbons from the opened flaps.
  19. Nintendo 3DS XL Upper LCD Display Replacement: step 19, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 19, image 2 of 2
    • Using the flat head side of the spudger carefully lift up the flap that attaches the ribbon to the motherboard.
    • For this flap lift from the black side.
    • Remove the ribbon from the flap.
    • Reassembly: This wide ribbon is the one with the BLACK STRIPE and goes on the upper (visible) side of the motherboard during reassembly.
  20. Nintendo 3DS XL Upper LCD Display Replacement: step 20, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 20, image 2 of 2
    • Remove ten 3.0 mm screws that are located around the face of the motherboard.
  21. Nintendo 3DS XL Upper LCD Display Replacement: step 21, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 21, image 2 of 2
    • The motherboard will still be attached at the top right hand corner so do not completely detach it at this point.
    • Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
    • Gently flip the motherboard over the top side.
  22. Nintendo 3DS XL Upper LCD Display Replacement: step 22, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 22, image 2 of 2
    • Using the flat head side of the spudger carefully lift up the flap that attaches the wider ribbon on the upper right side to the motherboard.
    • Make sure to lift the flap from the white side.
    • Remove the ribbon from the opened flap.
    • Set the motherboard aside.
  23. Nintendo 3DS XL Upper LCD Display Replacement, Upper LCD: step 23, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement, Upper LCD: step 23, image 2 of 2
    • Open the device such that the upper LCD is on top.
    • Using tweezers remove the four rubber pieces that are in all four corners.
  24. Nintendo 3DS XL Upper LCD Display Replacement: step 24, image 1 of 2 Nintendo 3DS XL Upper LCD Display Replacement: step 24, image 2 of 2
    • Remove the four 4.3 mm screws located underneath the four rubber pieces with a Phillips #00 screwdriver head.
  25. Nintendo 3DS XL Upper LCD Display Replacement: step 25, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 25, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 25, image 3 of 3
    • Flip over the device and close the hinge.
    • Position your fingers at the top of the hinge and push downwards in order to push the cover downwards away from the hinge. It only moves 2mm (1/8").
  26. Nintendo 3DS XL Upper LCD Display Replacement: step 26, image 1 of 1
    • Once the top case is loose and unclipped, remove it from the DS.
  27. Nintendo 3DS XL Upper LCD Display Replacement: step 27, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 27, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 27, image 3 of 3
    • Remove the screw that is holding 3D mechanism toggle button in place.
    • Carefully pull off the ribbons that connect the camera and speakers to the Upper LCD.
    • The ribbons are attached with adhesives so take caution while removing.
  28. Nintendo 3DS XL Upper LCD Display Replacement: step 28, image 1 of 1
    • Remove the two small ribbons located on the upper left corner.
    • Using a spudger lift up the black hinges that connect the ribbons to the bracket.
    • Pull the ribbons out of the bracket.
  29. Nintendo 3DS XL Upper LCD Display Replacement: step 29, image 1 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 29, image 2 of 3 Nintendo 3DS XL Upper LCD Display Replacement: step 29, image 3 of 3
    • Open the hinge and carefully pop off the Upper LCD using your fingers.
    • Gently remove the ribbon from the hinge.
    • Though not required, the task of removing the ribbon cables becomes much easier once you remove the hinge barrel on the right side of the device.
    • Do not lose the tiny fabric and rubber water-resistant rectangles that cover the two speakers; they often fall out once the speakers are removed.
    • The screen's cover glass can be replaced or transferred to your new screen. The cover is easily scratched by metal tools; use plastic or your fingernail to separate it.
    • Adhere the cover to the new screen by using thin adhesive around the edges, or by reusing the old adhesive.
Charlene Donlon
10,243 Reputation
8 Guides authored
Cal Poly, Team 9-13, Regan Spring 2014 Member of Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Members
44 Guides authored
Past 24 Hours: 105
Past 7 Days: 657
Past 30 Days: 2,985
All Time: 268,112
