Nintendo 3DS Wi-Fi Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nintendo 3DS Wi-Fi Board Replacement, Wi-Fi Board: step 1, image 1 of 2 Nintendo 3DS Wi-Fi Board Replacement, Wi-Fi Board: step 1, image 2 of 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  2. Nintendo 3DS Wi-Fi Board Replacement: step 2, image 1 of 3 Nintendo 3DS Wi-Fi Board Replacement: step 2, image 2 of 3 Nintendo 3DS Wi-Fi Board Replacement: step 2, image 3 of 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
David Hodson
150,535 Reputation
127 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 207
