Nintendo 3DS SD Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nintendo 3DS SD Board Replacement, SD Board: step 1, image 1 of 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  2. Nintendo 3DS SD Board Replacement: step 2, image 1 of 2 Nintendo 3DS SD Board Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  3. Nintendo 3DS SD Board Replacement: step 3, image 1 of 3 Nintendo 3DS SD Board Replacement: step 3, image 2 of 3 Nintendo 3DS SD Board Replacement: step 3, image 3 of 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
David Hodson
150,758 Reputation
127 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 248
