Nintendo 3DS Right Shoulder Button Replacement
  1. Nintendo 3DS Right Shoulder Button Replacement, Back Cover: step 1, image 1 of 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Right Shoulder Button Replacement: step 2, image 1 of 2 Nintendo 3DS Right Shoulder Button Replacement: step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Right Shoulder Button Replacement, Lower Case: step 4, image 1 of 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Right Shoulder Button Replacement: step 5, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 5, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 5, image 3 of 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 3 of 3
    • Remove the three 3.6 mm Phillips screws securing the metal battery shield to the lower case.
    • Lift the battery shield up and out of the lower case.
  7. Nintendo 3DS Right Shoulder Button Replacement: step 7, image 1 of 1
    • Remove the 3.6 mm Phillips screw from the right shoulder button cover.
  8. Nintendo 3DS Right Shoulder Button Replacement: step 8, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 8, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 8, image 3 of 3
    • Insert a plastic opening tool under the left side of the right shoulder button cover.
    • Pry the black plastic cover up from the lower case.
    • Grab the cover and lift it off of the lower case.
    • If the shoulder button contact and ribbon cable come off with the cover, be sure to reinstall them in the correct orientation.
  9. Nintendo 3DS Right Shoulder Button Replacement: step 9, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 9, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 9, image 3 of 3
    • Lift the right shoulder button out of the lower case.
    • The shoulder button is held in place by a metal pin, and houses a small spring. Take care not to lose track of either of these pieces when removing the shoulder button.
David Hodson
150,535 Reputation
127 Guides authored
Past 24 Hours: 26
Past 7 Days: 222
Past 30 Days: 941
All Time: 110,718
