Nintendo 3DS Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: step 2, image 1 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 2, image 2 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: step 3, image 1 of 2 Nintendo 3DS Motherboard Assembly Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: step 4, image 1 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 4, image 2 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 4, image 3 of 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: step 5, image 1 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 5, image 2 of 3 Nintendo 3DS Motherboard Assembly Replacement: step 5, image 3 of 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
  6. Nintendo 3DS Motherboard Assembly Replacement: step 6, image 1 of 1
    • Remove the motherboard assembly from the rest of the device.
David Hodson
150,712 Reputation
127 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,593
