Installing Nintendo 3DS Lower Display Assembly
  1. Installing Nintendo 3DS Lower Display Assembly, Back Cover: step 1, image 1 of 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Installing Nintendo 3DS Lower Display Assembly: step 2, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Installing Nintendo 3DS Lower Display Assembly, Battery: step 3, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly, Battery: step 3, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Installing Nintendo 3DS Lower Display Assembly, Lower Case: step 4, image 1 of 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Installing Nintendo 3DS Lower Display Assembly: step 5, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 5, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 5, image 3 of 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Installing Nintendo 3DS Lower Display Assembly, Circle Pad Joystick: step 6, image 1 of 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  7. Installing Nintendo 3DS Lower Display Assembly: step 7, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 7, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 7, image 3 of 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. Installing Nintendo 3DS Lower Display Assembly: step 8, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 8, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 8, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
  9. Installing Nintendo 3DS Lower Display Assembly: step 9, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 9, image 2 of 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
  10. Installing Nintendo 3DS Lower Display Assembly, SD Board: step 10, image 1 of 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. Installing Nintendo 3DS Lower Display Assembly: step 11, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 11, image 2 of 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. Installing Nintendo 3DS Lower Display Assembly: step 12, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 12, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 12, image 3 of 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
  13. Installing Nintendo 3DS Lower Display Assembly, Wi-Fi Board: step 13, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly, Wi-Fi Board: step 13, image 2 of 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. Installing Nintendo 3DS Lower Display Assembly: step 14, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 14, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 14, image 3 of 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
  15. Installing Nintendo 3DS Lower Display Assembly, Motherboard Assembly: step 15, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly, Motherboard Assembly: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. Installing Nintendo 3DS Lower Display Assembly: step 16, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 16, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 16, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  17. Installing Nintendo 3DS Lower Display Assembly: step 17, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 17, image 2 of 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  18. Installing Nintendo 3DS Lower Display Assembly: step 18, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 18, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 18, image 3 of 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  19. Installing Nintendo 3DS Lower Display Assembly: step 19, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 19, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 19, image 3 of 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  20. Installing Nintendo 3DS Lower Display Assembly: step 20, image 1 of 1
    • Remove the motherboard assembly from the rest of the device.
  21. Installing Nintendo 3DS Lower Display Assembly, Lower Display Assembly: step 21, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly, Lower Display Assembly: step 21, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly, Lower Display Assembly: step 21, image 3 of 3
    • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
    • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
  22. Installing Nintendo 3DS Lower Display Assembly: step 22, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 22, image 2 of 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the touchscreen ribbon cable ZIF socket.
  23. Installing Nintendo 3DS Lower Display Assembly: step 23, image 1 of 3 Installing Nintendo 3DS Lower Display Assembly: step 23, image 2 of 3 Installing Nintendo 3DS Lower Display Assembly: step 23, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
    • Pull the ribbon cable out of the connector with a pair of tweezers.
    • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
  24. Installing Nintendo 3DS Lower Display Assembly: step 24, image 1 of 2 Installing Nintendo 3DS Lower Display Assembly: step 24, image 2 of 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD data ribbon cable ZIF socket.
  25. Installing Nintendo 3DS Lower Display Assembly: step 25, image 1 of 1
    • Grasp the lower display assembly and pull it directly away from the motherboard.
David Hodson
150,712 Reputation
127 Guides authored
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 104
All Time: 8,656
