Nintendo 3DS Battery Replacement
  1. Nintendo 3DS Battery Replacement, Back Cover: step 1, image 1 of 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: step 2, image 1 of 2 Nintendo 3DS Battery Replacement: step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Battery Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Battery Replacement, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
David Hodson
150,503 Reputation
127 Guides authored
Past 24 Hours: 48
Past 7 Days: 497
Past 30 Days: 2,211
All Time: 67,676
