Introduction
If your C-Stick doesn't work you may need to replace it. Watch out for delicate ribbon cables in the device. After removing the board with the C-Stick attached the face buttons can fall out. Make sure not lose them.
Pull the top corner tabs of the front face plate outward and towards you.
Pull the faceplate up and out of the slots at the bottom of the device.
Set aside the back faceplate.
Insert a plastic opening tool into the notch at the top of the battery.
Pry the battery up with the plastic opening tool.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
Reorient the device so that the power jack faces you.
Lift the SD card reader gently.
Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
Lift the SD card reader out off of the lower casing.
Lift the top edge of the lower case slightly off on the 3DS.
Pry the ribbon cable socket under the right trigger using a plastic opening tool.
Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
Pry the last ribbon cable attached to the lower case using a plastic opening tool.
Pull up gently on power cable to loose it from the motherboard.
Pull the ribbon cable, connected to the mic, gently towards you with a pair of tweezers.
Lift the tab to free the large ribbon cable on just above the power connector.
Pry the C-Stick from its plastic housing with the flat side of a spudger.
Lift the assembly gently out of the device from the battery connector at the bottom of the leftmost circuit board.
Flip the board over to reveal the connector for the C-stick's ribbon cable.
Lift the tab on the ZIF connector securing the C-Stick to the board.
Separate the C-Stick from the board.
