Introduction
If your battery isn't holding a charge or won't charge you may consider replacing the battery. Press hard and go slow on the screws in the back panel they are soft and strip easily.
Pull the top corner tabs of the front face plate outward and towards you.
Pull the faceplate up and out of the slots at the bottom of the device.
Set aside the back faceplate.
Insert a plastic opening tool into the notch at the top of the battery.
Pry the battery up with the plastic opening tool.
