Nintendo Wii Remote Main Buttons Replacement
Views: 50K
View statistics:
Past 24 Hours:
11
Past 7 Days:
97
Past 30 Days:
358
All Time:
50,471
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Removing the main buttons requires opening the device. The main buttons include all buttons except the trigger style B button.
Tools
    1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
      Ask FixBot
    2. Nintendo Wii Remote Main Buttons Replacement: step 2, image 1 of 1
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
      Ask FixBot
    3. Nintendo Wii Remote Main Buttons Replacement: step 3, image 1 of 1
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
      Ask FixBot
    4. Nintendo Wii Remote Main Buttons Replacement: step 4, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement: step 4, image 2 of 2
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
      Ask FixBot
    1. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 2 of 2
      • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
      Ask FixBot
    2. Nintendo Wii Remote Main Buttons Replacement: step 6, image 1 of 1
      • Flip over the cover, allowing the buttons to fall into your hand.
      • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
      • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
      • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
      Ask FixBot
27 other people completed this guide.
Emily
2,030 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
72 Guides authored
5 Guide Comments
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Reply Share
Me too, can’t find them.
Michael Velten - Reply Share
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Reply Share
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - Reply Share
Yo tampoco los encuentro por ninguna parte
kinoto taller - Reply Share
Past 24 Hours: 11
Past 7 Days: 97
Past 30 Days: 358
All Time: 50,471
