Ninja Ultima BL810 Blade Replacement
  1. Ninja Ultima BL810 Blade Replacement, Single Serving Blade: step 1, image 1 of 2 Ninja Ultima BL810 Blade Replacement, Single Serving Blade: step 1, image 2 of 2
    • Remove the lid from the container by twisting the lid counter clockwise.
  2. Ninja Ultima BL810 Blade Replacement: step 2, image 1 of 2 Ninja Ultima BL810 Blade Replacement: step 2, image 2 of 2
    • Use pliers to grip the nut on the bottom of the lid.
    • Make sure to hold tight on the blade with a towel or glove to make sure you do not cut your hand.
    • Twist the pliers counter clockwise while holding the blade to remove from lid.
    • Make sure to keep track of each piece once disassembled.
Donald Syracuse
213 Reputation
2 Guides authored
Cal Poly, Team S9-G4, Banghart Fall 2017 Member of Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 3,545
