Ninja Professional BL610 Circuit Board Replacement
  1. Ninja Professional BL610 Circuit Board Replacement, Circuit Board: step 1, image 1 of 1
    • Remove six screws (13mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver
  2. Ninja Professional BL610 Circuit Board Replacement: step 2, image 1 of 1
    • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
  3. Ninja Professional BL610 Circuit Board Replacement: step 3, image 1 of 1
    • Remove six screws (9mm long, 2mm head diameter) from component housing using Phillips #2 screwdriver
  4. Ninja Professional BL610 Circuit Board Replacement: step 4, image 1 of 1
    • Locate the black and red wire that connect to the circuit. Locate where they are soldered on the back.
  5. Ninja Professional BL610 Circuit Board Replacement: step 5, image 1 of 1
    • Desolder both wires from the solder pads shown.
3 other people completed this guide.
Rosniel Castro
482 Reputation
4 Guides authored
USF Tampa, Team S14-G3, Boczar Fall 2017 Member of USF Tampa, Team S14-G3, Boczar Fall 2017
USFT-BOCZAR-F17S14G3
4 Members
6 Guides authored
12 Guide Comments
hi , my friend just recently purchased a Model B611 from Canada and brought it home here in the Philippines. In all of her excitement failed to first check for the working voltage, and plugged it in to a 220-240 volt outlet, and the rest is history. I tried comparing the board on your illustration, and it seems like that their one and the same, just want to verify.My board is showing BL610 (K01-BC-11-02) would it be safe to try to purchase the board showing here on your guide for the model B610? and where could I order one, if I choose to replace the whole board. Another option would be to try to replace the blown parts, varistor, film capacitor and the transistor
alfred leung - Reply
Looks like I found the solution to my own problem, instead of attempting to swap out the board , I replaced the burnt out varistor, then proceeded to add on jumper wires to bridge the damaged plating around the varistor and power lead in. The varistor actually saved the day , since no fuse was included in the board design. Blender is now up and running. Also added a sticker to remind the user that the unit is a 120v only appliance.
alfred leung -
Ninja often puts a trace fuse in on high volume products.
Liam Fionlhiason -
Followed the disassembly instruction, helped me a lot!!!
Please, were I can find a new board to buy?
My Blender is a BL-710 MW30 120V NFB 1000W, but the circuit board is “BL610 (K01-BC-11-02) “.
Thank for any help.
Jean
Jean Ligocki - Reply
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 172
All Time: 3,743
