Ninja NJ600 Power Cord Replacement
  1. Ninja NJ600 Power Cord Replacement, Blender Base Cover: step 1, image 1 of 2 Ninja NJ600 Power Cord Replacement, Blender Base Cover: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Power Cord Replacement: step 2, image 1 of 2 Ninja NJ600 Power Cord Replacement: step 2, image 2 of 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Power Cord Replacement: step 3, image 1 of 3 Ninja NJ600 Power Cord Replacement: step 3, image 2 of 3 Ninja NJ600 Power Cord Replacement: step 3, image 3 of 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Power Cord Replacement, Power Cord: step 4, image 1 of 1
    • Remove these two screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
  5. Ninja NJ600 Power Cord Replacement: step 5, image 1 of 1
    • Your blender and power cord should look like this now that the two screws have been removed.
    • In the next steps we will highlight two issues that your power cord may have.
  6. Ninja NJ600 Power Cord Replacement: step 6, image 1 of 1
    • Your power cord is soldered to the circuit board as shown.
    • A loose or damaged connection could explain why your blender is not turning on.
    • Desolder the connection using the iFixit guide that describes this process.
    • Solder the wires back on to the circuit board. Refer to the iFixit soldering guide for assistance.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Power Cord Replacement: step 7, image 1 of 2 Ninja NJ600 Power Cord Replacement: step 7, image 2 of 2
    • If there were no issues with the soldering connection in Step 6, check the wiring in the picture shown.
    • Remove the zip ties with a pair of scissors. Then remove the plastic that covers the wires.
    • If the wires underneath the plastic covers are loose or disconnected, try to desolder and solder the wires. Use the iFixit soldering guide to assist in this step.
Trevor Waite
275 Reputation
1 Guide authored
Cal Poly, Team 24-2, Lancaster Spring 2015 Member of Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,962
