Ninja NJ600 Button Replacement
  1. Ninja NJ600 Button Replacement, Blender Base Cover: step 1, image 1 of 2 Ninja NJ600 Button Replacement, Blender Base Cover: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Button Replacement: step 2, image 1 of 2 Ninja NJ600 Button Replacement: step 2, image 2 of 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Button Replacement: step 3, image 1 of 3 Ninja NJ600 Button Replacement: step 3, image 2 of 3 Ninja NJ600 Button Replacement: step 3, image 3 of 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Button Replacement, Circuit Board: step 4, image 1 of 1
    • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
    • Be careful not to scratch the circuit board with the screwdriver.
  5. Ninja NJ600 Button Replacement: step 5, image 1 of 1
    • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
    • This will give the circuit board more range of motion.
  6. Ninja NJ600 Button Replacement: step 6, image 1 of 3 Ninja NJ600 Button Replacement: step 6, image 2 of 3 Ninja NJ600 Button Replacement: step 6, image 3 of 3
    • Desolder the five wires from the solder pads shown.
    • If you do not know how to do this, iFixit has a guide describing the process.
    • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Button Replacement: step 7, image 1 of 1
    • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
    • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
  8. Ninja NJ600 Button Replacement, Button: step 8, image 1 of 2 Ninja NJ600 Button Replacement, Button: step 8, image 2 of 2
    • After removing the circuit board from your device, locate which button you wish to replace.
    • On the opposite side of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
  9. Ninja NJ600 Button Replacement: step 9, image 1 of 1
    • Desolder these four solder pads.
    • These pads are small, so take care to not damage the circuit board.
    • NOTE: the orientation of the buttons is important. Make sure you place the new button in the correct orientation.
Kody D
537 Reputation
3 Guides authored
Cal Poly, Team 24-2, Lancaster Spring 2015 Member of Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,231
