Introduction
In the chance that your circuit board stops working, this step-by-step guide will show you how to replace it. For soldering help, follow the How to Solder and Desolder Connections guide.
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Where can I buy a new board?
Mein yeh circuit board kharidna chahta hoon kha se milega
Cautiously desolder all the wires connecting the circuit board to the unit.
Carefully slide the circuit board free of the wires are place the new board in.
Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
5 other people completed this guide.
14 Comments
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Anyone know the chip on this circuit board?? Proprietary I assume??
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
Hi Tom:
My BL770 turns the button on and off as soon as any button is pressed. To turn it on again, it must be disconnected. What could be the damage? Thank you.
Hello . Did you find the pcb anywhere?
Are you have pcb nijnja blender BL685.How much price??..
