Introduction
The magnetic rotating shaft powers the spinning mechanism inside the Ninja Creami. If the machine isn’t spinning correctly or is making unusual noises, the shaft may need to be removed. Be careful when handling internal parts to avoid damaging gears or misaligning components. Always unplug the device before starting.
On the NC301 model: on the bottom of each side, remove the two Security T-10 screws that attach the grey cover to the black housing.
Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
Disconnect the daughterboard's motherboard connector.
Remove the daughter board.
10 Guide Comments
Is there a replacement shaft anywhere online I could buy?
Also interested in purchasing a rotating shaft...
@jimcampbel74320 Did any of you manage to find this replacement part? I'm also looking for this part.
