Ninja Creami Outer Shell Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
146
All Time:
1,390
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Before replacing the motherboard, daughter board, or internal mechanical parts, you’ll need to carefully open the device to expose its inner components. This guide will walk you through the disassembly process required to reach the internal hardware safely.
Be sure to unplug the device and work on a clean, static-free surface. Handle all parts carefully, especially wiring and small connectors.
Tools
    1. Ninja Creami Outer Shell Replacement, Outer Shell: step 1, image 1 of 2 Ninja Creami Outer Shell Replacement, Outer Shell: step 1, image 2 of 2
      • On the NC301 model: on the bottom of each side, remove the two Security T-10 screws that attach the grey cover to the black housing.
      • Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
      • Start at one edge and work your way around to avoid cracking the housing.
      Ask FixBot
    2. Ninja Creami Outer Shell Replacement: step 2, image 1 of 3 Ninja Creami Outer Shell Replacement: step 2, image 2 of 3 Ninja Creami Outer Shell Replacement: step 2, image 3 of 3
      • Remove the ten 13.6 mm Phillips screws from the perimeter of the outer cover.
      • On the NC301 model: you also need to remove the two Security T-10 screws below the button panel and near the rotating shaft housing.
      • Lift the black plastic cover straight up and off.
      • On the NC301 model: the control board behind the button panel is attached to this part and will come off with it. Be careful not to stretch or pull out the ribbon cable that connects it to the rest of the unit.
      Ask FixBot
    3. Ninja Creami Outer Shell Replacement: step 3, image 1 of 2 Ninja Creami Outer Shell Replacement: step 3, image 2 of 2
      • Remove the four 12.2 mm Phillips screws from the black plastic cover.
      Ask FixBot
Karlee B
712 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 146
All Time: 1,390
