Ninja Creami Daughterboard Replacement
  1. Ninja Creami Daughterboard Replacement, Outer Shell: step 1, image 1 of 2 Ninja Creami Daughterboard Replacement, Outer Shell: step 1, image 2 of 2
    • Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
    • Start at one edge and work your way around to avoid cracking the housing.
    Ask FixBot
  2. Ninja Creami Daughterboard Replacement: step 2, image 1 of 3 Ninja Creami Daughterboard Replacement: step 2, image 2 of 3 Ninja Creami Daughterboard Replacement: step 2, image 3 of 3
    • Remove the ten 13.6 mm Phillips screws from the perimeter of the outer cover.
    • Lift the black plastic cover straight up and off.
    Ask FixBot
  3. Ninja Creami Daughterboard Replacement: step 3, image 1 of 2 Ninja Creami Daughterboard Replacement: step 3, image 2 of 2
    • Remove the four 12.2 mm Phillips screws from the black plastic cover.
    Ask FixBot
  4. Ninja Creami Daughterboard Replacement, Daughterboard: step 4, image 1 of 2 Ninja Creami Daughterboard Replacement, Daughterboard: step 4, image 2 of 2
    • Disconnect the daughterboard's motherboard connector.
    • Remove the daughter board.
    Ask FixBot
Karlee B
712 Reputation
6 Guides authored
1 Guide Comment
Hi, where can I buy the schaft? Give me the link, thanks Lucas.
LukeCornerFeno Gmail - Reply Share
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 160
All Time: 1,087
