Shop the Holiday Gift Guide
Ninja Coffee Bar CF080 Power Module Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
30
Past 30 Days:
110
All Time:
4,621
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show how to remove the power module from the coffee machine.
Tools
    1. Ninja Coffee Bar CF080 Power Module Replacement, Heated Plate: step 1, image 1 of 1
      • Face the machine bottom towards you.
      Ask FixBot
    2. Ninja Coffee Bar CF080 Power Module Replacement: step 2, image 1 of 2 Ninja Coffee Bar CF080 Power Module Replacement: step 2, image 2 of 2
      • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
      • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
      Ask FixBot
    3. Ninja Coffee Bar CF080 Power Module Replacement: step 3, image 1 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 3, image 2 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 3, image 3 of 3
      • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
      Ask FixBot
    4. Ninja Coffee Bar CF080 Power Module Replacement: step 4, image 1 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 4, image 2 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 4, image 3 of 3
      • Remove the bottom board with moderate force.
      Ask FixBot
    5. Ninja Coffee Bar CF080 Power Module Replacement: step 5, image 1 of 1
      • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
      • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
      Ask FixBot
    6. Ninja Coffee Bar CF080 Power Module Replacement: step 6, image 1 of 1
      • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
      • The silver bar will fall off once screws are removed.
      Ask FixBot
    7. Ninja Coffee Bar CF080 Power Module Replacement: step 7, image 1 of 2 Ninja Coffee Bar CF080 Power Module Replacement: step 7, image 2 of 2
      • Remove the heated plate from the machine with easy glide.
      Ask FixBot
    1. Ninja Coffee Bar CF080 Power Module Replacement, Power Module: step 8, image 1 of 3 Ninja Coffee Bar CF080 Power Module Replacement, Power Module: step 8, image 2 of 3 Ninja Coffee Bar CF080 Power Module Replacement, Power Module: step 8, image 3 of 3
      • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
      • Some screws are harder to see due to how deep the holes are.
      • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
      Ask FixBot
    2. Ninja Coffee Bar CF080 Power Module Replacement: step 9, image 1 of 2 Ninja Coffee Bar CF080 Power Module Replacement: step 9, image 2 of 2
      • Remove the two 0.6cm with Phillips #2 screwdriver.
      Ask FixBot
    3. Ninja Coffee Bar CF080 Power Module Replacement: step 10, image 1 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 10, image 2 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 10, image 3 of 3
      • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
      • There with be 1 blue, 1 black, 1 red and 2 white.
      Ask FixBot
    4. Ninja Coffee Bar CF080 Power Module Replacement: step 11, image 1 of 2 Ninja Coffee Bar CF080 Power Module Replacement: step 11, image 2 of 2
      • Remove the black board by maneuvering it through the cords.
      Ask FixBot
    5. Ninja Coffee Bar CF080 Power Module Replacement: step 12, image 1 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 12, image 2 of 3 Ninja Coffee Bar CF080 Power Module Replacement: step 12, image 3 of 3
      • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
      Ask FixBot
    6. Ninja Coffee Bar CF080 Power Module Replacement: step 13, image 1 of 2 Ninja Coffee Bar CF080 Power Module Replacement: step 13, image 2 of 2
      • Remove the three 0.6cm screws with Phillips #1 screwdriver.
      • They are in the black holes, 1 at the top and two at the bottom.
      Ask FixBot
    7. Ninja Coffee Bar CF080 Power Module Replacement: step 14, image 1 of 1
      • Remove the black board attached to the module.
      Ask FixBot
2 other people completed this guide.
Author
with
Elizabeth Nguyen
416 Reputation
3 Guides authored
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 110
All Time: 4,621
