Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement
  1. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: step 1, image 1 of 2 Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: step 1, image 2 of 2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: step 2, image 1 of 1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: step 3, image 1 of 1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: step 4, image 1 of 1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
Naser Aldousari
310 Reputation
3 Guides authored
USF Tampa, Team S13-G69, Cagle Fall 2017 Member of USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 885
