Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
Note from a user: the screws were not Philips. They are JIS. Even PH0000 wouldn't fit. I got 4 stripped screws on my D90.
On the bottom of the camera,
remove the two 5.3mm Phillips screws
and the other two 6.3mm Phillips screws.
Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
Lift the rear case off of the back of the camera.
Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
