Nikon D70 Flash Repair
  1. Nikon D70 Flash Repair, Nikon D70 Flash Repair: step 1, image 1 of 2 Nikon D70 Flash Repair, Nikon D70 Flash Repair: step 1, image 2 of 2
    • Make sure the flash is open.
    • Remove the battery and the lens. To remove the lens, face camera toward you, press the button as shown, and rotate the lens clockwise.
    • Replace the lens with a lens cover. This will keep dirt and tools from damaging the inside of the camera.
  2. Nikon D70 Flash Repair: step 2, image 1 of 1
    • Unscrew the flash cover with a small Phillips #000 screwdriver.
    • Note: The screws are angled slightly toward the outside of the flash unit.
  3. Nikon D70 Flash Repair: step 3, image 1 of 3 Nikon D70 Flash Repair: step 3, image 2 of 3 Nikon D70 Flash Repair: step 3, image 3 of 3
    • To the far left of the wiring is a small metal hook. There is a plastic cylinder by the hook . This hook needs to wrap over the white cylinder for a full electrical circuit to be complete.
    • Notice that there are 2 little plastic tabs that block the cylinder body. You will need to depress them and then pull the cylinder body out towards you. Hook the metal hook over the white plastic cylinder.
    • CAUTION: Do not touch any metal on the camera while repairing the flash. Even though the battery is removed, the capacitor can give you quite a zap. not break the insulation of a wire as both could electrocute you. Also, be very careful not to damage any wires.
  4. Nikon D70 Flash Repair: step 4, image 1 of 1
    • To reassemble, reverse the steps. Now go out and take some pictures!
Andres Matias Dabas
205 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 44
All Time: 5,126
