Olympus Stylus 410 Shutter Button Replacement
    1. Olympus Stylus 410 Shutter Button Replacement, Shutter Button: step 1, image 1 of 3 Olympus Stylus 410 Shutter Button Replacement, Shutter Button: step 1, image 2 of 3 Olympus Stylus 410 Shutter Button Replacement, Shutter Button: step 1, image 3 of 3
      • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
      Ask FixBot
    2. Olympus Stylus 410 Shutter Button Replacement: step 2, image 1 of 2 Olympus Stylus 410 Shutter Button Replacement: step 2, image 2 of 2
      • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
      • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
      Ask FixBot
    3. Olympus Stylus 410 Shutter Button Replacement: step 3, image 1 of 2 Olympus Stylus 410 Shutter Button Replacement: step 3, image 2 of 2
      • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
      Ask FixBot
Rory Aronson
82 Reputation
6 Guides authored
Cal Poly, Team 6-13, Maness Spring 2010 Member of Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 31
Past 30 Days: 87
All Time: 3,750
